MDR 1000x firmware update
esg.esg
New
Hi. Is there a MDR 1000x firmware update? I couldn't find one. Moreover, the 'Sony Headphones Connect' app doesn't recognizes it, which supposedly should allow a firmware update. Thanks.
2 REPLIES 2
profile.country.DE.title
IamNic
Hello @esg.esg,
there is no firmware update available for the headphones, meaning they are up to date.
Also they are not compatible with the Headphones Connect App.
On this page you can see which headphones are compatible with the app: https://www.sony.co.uk/electronics/headphones-connect-app
- Nic
esg.esg
New
Hi Nic,
Thx a bunch for your reply. Since a few years ago when I bought this product, it was leading the market in the noise canceling products. Do you know if Sony will engage its engineering department to continue with supporting this headset?
esg
