Hi! I wonder if any of you have experienced the same issue as I have. I've recently switched from iPhone 6s to iPhone 11 and there seem to be some sound quality issues on the 11.
While playing music, after a few seconds of perfect quality, the sound coming from Sony WF-1000xm3 turns muted – it's especially audible in high frequencies. It's as if the sound got compressed to a lower quality. I tried this on two different iPhones 11 and they behave the same way. iPhone 6s, however, still plays music perfectly, even after updating to iOS 13.1.1. All three phones run the same software and I know that there have been some issues with iOS 13.1.1 but they don't seem to affect the older iPhone 6s (or iPad Pro for that matter). Is it possible that the new iPhones use some different codec or Bluetooth version and Sony has to update their companion app in order for the headphones to perform like intended? Or is iPhone 11 just doomed and we'll have to deal with unpleasant sound from now on?
I also checked the sound quality of WH-1000xm2 for comparison and there are no issues with it on any of the devices.
Thank you for any input!
Maciej
Apparently, the new Sony WF-1000XM3 model is having issues with any devices of iOS 13.0 or higher. I have iOS 13.2 beta on my iPhone XR and wanted to update my earbuds firmware so that the issues with connecting to a windows 10 laptop would no longer exist, but unfortunately, I wasn't able to. who should we contact regarding this? I have no idea, but I already reported feedback about it to Apple.
Hi,
I’ve not had your specific problem, but I have had volume changing problems between my iPhone 6s (iOS 12 & 13) and my WH1000XM2 headphones.
This happened when I removed my headphones, but leaving them switched on. After 5-15 minutes I would put them back on. However, the volume was now at least 3 times louder. Through trial and error, I toggled the NC switch off and on and the headphone volume would reduce back to its original, quieter level. Weird.
I have an iPhone 11 and I am experiencing poor sound quality with my new WF-1000xm3 earbuds. I have the Sony WF-1000XM2 over the ear noise canceling headphones that sound great but I’m so disappointed in the newly released earbuds
My Problem fixed. Try it too.
it wasn’t easy.
Note:
Apple Notifications for App Store updates is not working (it’s enabled on my iPhone), so I was unaware that the Sony Headphone Connect app had been updated from 6.0.1 to 6.0.3
I decided to restore my iPhone. All the apps reloaded, but importantly, they did so to the latest revision, in the case of Sony Headphone Connect, this is 6.0.3.
Using iOS 13.2 beta 2 with v6.0.3 of Sony Headphone Connect has solved my problem. Music played for 2 hours without any power downs.
Update the Sony Headphone Connect app to 6.0.3
