I need to disconnect my car battery
SOLVED
profile.country.en_IE.title
colj60
Visitor
Will I need a code for my CDX-S2000c when I reconnect?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
Drumzman
New
Hi colj60,
The security was a removable front panel on this unit, so there is no code required (manual confirms this).  You might have to perform a reset after you've restored the power though.
Hope this helps.
2 REPLIES 2
Drumzman
New
Hi colj60,
Hope this helps.
colj60
Visitor
Thank you
