Firmware update NWZ E436F
SOLVED
profile.country.en_GB.title
elscott11
Visitor
I have been trying to update the firmware on my NWZ E436F. I use windows 7. I downloaded the update to a folder on my c drive as per the instructions on the Sony site but where do I go from there? Hope someone can help.
1 ACCEPTED SOLUTION
Accepted Solutions
elscott11
Visitor
Thanks for ypor reply. I was trying to update (unsuccessfully) using my laptop which is 64 bit. I have now installed the update successfully using my "old" desktop which is 32 bit.:smileyhappy:
3 REPLIES 3
Thalamus.
Champion
Hi elscott11,
welcome to Questions & Answers..:smileyhappy:
Have you followed the How to Update instructions from the support site - NWZ-E436F Update guide
elscott11
Visitor
Thalamus.
Champion
Ah, glad you've managed to resolve the problem & successfully update your Walkman..:smileyhappy:
