Hello i recently purchased a new laptop running windows 7. My minidisc MZ-RH710 will not run it says driver missing. i've tried all afternoon to find a driver to no avail, has anybody got any ideas if one is available or a way of curing this problem? thank you lindo123
Hi lindo123 and welcome.
Is your PC running 32 or 64-bit Windows 7?
I can only find the Vista driver which needs SonicStage 4.3 on the Support Pages for your product
http://www.sony.co.uk/support/en/topics/vista/himd#vistainfo
Microsoft say 64-bit is compatible: -
Give it a try.
Thank you for your reply Blencogo. I'm running windows 7 home premium sp1 64 bit.
I downloaded from the link above but it says driver missing, and simple burner says not supported o/s.
Have you any other ideas if so i would appreciate further suggestions. Thank you. lindo123
