CDX-GT35U night-mode
SOLVED
profile.country.cs_CZ.title
26262626
Visitor
Hi! Have a display of CDX-GT35U night-mode? How I turn on?
Tags (2)
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
Drumzman
New
Hello,
The only thing I can think of is the dimmer function - to make the display less bright at night?  I hope this is what you are trying to find out?
To turn the dimmer on and off:
Press and hold the 'select' button (the setup display appears).
Then repeatedly press the 'select' button until "DIM" (dimmer) appears.
Turn the control knob to turn the dimmer on or off.
Press and hold the 'select' button again to confirm the setting for the dimmer and exit setup.
Hope this helps?
3 REPLIES 3
Drumzman
New
Hello,
Hope this helps?
26262626
Visitor
Thank you very much, my friend:smileycool:
Drumzman
New
No problem - glad it helped! :slight_smile:
