Hi all,
is it possibile to connect xl201 to tv through hdmi and to monitor through componennt simoultaneously ?
Thank you!
Hi there,
I've not tried it on Windows 7, but have my TV connected over HDMI and a Sony projector over component out. When i usually switch to projector on the old XP O/S i never saw the same image on both displays simultaneously, but perhaps it's changed now with either Vista or Win7.
p.s. XL201 Media Centre experience is much more reliable on Win7. Pre-order it now, whilst it's still half price (i paid £50 for the upgrade)
Regards, Tony
Hi Chalky,
if is possible to switch the signal it's a good thing.
Can I do that with the nvidia drivers settings?
For Media center i'm using mediaportal, I find it useful and easily configurable.
Thank you,
David
Yes David, you can switch using the Nvidia applet where it lets you choose the default screen, i.e. number 1 and number 2 screen. Regards, Tony
