Hello again,
OK - so i've got the Vaio VGN-AR51E. I've restored my disks and removed the majority of software on the PC, but there are a huge number of things left which i'd also like to remove. Here's the stuff I want to keep first....
Magic-I Visual Effects
ALL buttion functionality
Is there a definitive list which highlights what all of the installed software actually does? My Add/Remove list contains all of the following (minus stuff I want to keep)...
Ah never mind. I've stipped out everything from Sony! Not surprisingly, the only casualty was the on-screen volume display (the control still works) and the eject button. Once that was done and system restore was switched off, I got Vista running really smoothly.
I may later on, document exactly what I did in case someone else wants to give it a go. makes a big difference. (AR51E model)
Good work and congratulations on a superb site name
Lol...
Yeah. Can't believe how well this runs with vista stripped down of all the sony stuff. I only have two Sony installs left on this PC now (Wireless switched and Camera capture utility). It runs wonderfully now.
I have a Vaio SZ61 and I was soo impressed with the fast bootup (about 10 minuttes) and shutdowntime (another 10 minuttes), on a out of the box computer, so I installed Ubuntu as dual boot, and Ubuntu works really well with very little care after the install.
To insall ubuntu I used the recovery utility and used it to splitt my C: disk in to a C: and a 😧 disk.
Then I booted from the ubuntu CD and deleted the partition that used to be my 😧 disk (sda3 in ubuntu) and made a linux system disk on sda3 and a 2GB swap as sda4.
Ubuntu automatically detects all your disks and give you the option to choose at bootup what to start: recovery, windows or linux.
I would really like to know what I need to remove in Vista to get it to boot a little faster. Also my vista hangs and crashes all the time (maybe because I am used to real multitasking from Linux, and try to do to many things at once).
-Espen-
OK, man you motivated me. I already unistalled bunch of the Sony crap. But now I will get rid of more
Muhaaahahhaha
Specially the Vaio Content and Vaio Media files, anybody any idea what is it good for?
@JonnyThunder:
How did you repair ("eject button. Once that was done...") the eject button?
How did you uninstall Norton 360?
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=42359&offset=10
VGN-AR51E
Windows Vista Home Premium
Hey,
I own the AR51m and would love to see your guide.
cheers
I have a FZ21Z, and noticed there is alot of useless VAIO software installed, and would love to know what to uninstall to do what, I'm wanting similar functionality to what you've got now - I love the Magic-I cam thing, and want all the extra keys to work, S1, and the brightness, as well as media control pad.
I've toyed around uninstalling a few of them, and have accidentally uninstalled ones for the brightness controls, so if anyone knows which VAIO app makes them work again - would be much appreciated.
What do you mean by the Media Control Pad?
Well, I unistalled all the Vaio Content programs and Vaio Media files, and everything runs without change.
I would guess that the programs for the brighness and the buttons to work is either Vaio event service or Vaio control center.
