volume on Sony Media centre
Ivan2
Visitor
Since I uploaded vista bi have no sound. All the volume controls on the PC are up to full, but I still have no sound at all. Any advice???
6 REPLIES 6
Blencogo
Hi Ivan2 and welcome to Club Vaio.
What model Vaio do you have?
Do you get the Vista Start-up sounds when you boot?
:thinking:
Ivan2
Visitor
Hi Blencogo,
Thanks for answering.
I get nothing, zip, nada, nought, zero.
I had it all on XP, now i get nothing Ive run all the tests, checked all the drives, uploaded all the software updates from Sony and Microsoft, still nothing.
Ivan2
Ivan2
Visitor
Hi Blencogo
The model I have is a Sony Vaio media Centre VGX-XL202 with Blue ray.
Ivan2
profile.country.en_GB.title
kee-lo_
Member
If you're using a HD display or output make sure you've enabled HDMI/SDPIF output
Ivan2
Visitor
Hi Kee-lo,
Where do I find this;-
Ivan2
flash876
Visitor
Blencogo - I posted a thread a few months ago, ref my video capture doesn't work [XL 101] - I've since tried to install my Vista upgrade [Sony support told me it wouldn't hurt...]. i have since gone back to XP [Vista was worse!] using my recovery disk... I now have No Sound, or Video Capture!!!
My Hardwear wizard finds an uninstalled PCI Card - but can't find any drivers [net or disk]... Do you have any ideas??
sorry if this sounds like I've hijacked this thread - its just a sound/driver/install problem - which may be conected...
Cheers,
Flash
