Hi, Does anyone have a driver for the VN-CX1 skype mouse.. I have broken the disc I have that came with it, and Vista does not surport it on my Z series laptop. If anyone has it would be so great to get the file. Many thanks in advance Cliff
You need a driver update for compatibility with Vista (& hopefully Win 7). The original driver on the disc only supports up to XP.
There is a Vista driver download on the Sony Asia-Pacific website here: -
http://www.sony-asia.com/support/download/product/vn-cx1/modelfirst
Probably worth a try???? It should install without having the original installed as the instructions are to uninstall the previous version first.
