In windows when I "change the way user logs in" it gives me an error msg.
Windows tech support tell me its due to Sony software conflict.
Shouldnt there be an update on this to fix it >>???
Hi Actionman,
Are you able to make the changes in safe mode, press f8 repeatedly when starting your Vaio...
It would also help if you could post what changes to the user account you are trying to make and the error message you receive..
Everytime you start up windows you get a log in or a username/password entry. In my case with the fingerprint entry on my vaio.
In order to chage this I was told by Windows Tech support I needed to go into Control panel/User Accounts/User Accounts (again)/Change the way users log on/off.
But when I do I get a msg stating :
"A recently installed program has disabled the windows screen and fast user switching. To restore these features, you must uninstall the program.The following file name might help you identify the program that made the change: PSLogon.dll"
I cant for the life of me find the program and Windows tech support say its a Sony conflict problem.
HELP !
Bump
Bump
If I reinstall I lose everything.
Does anyone know how I could fix the problem apart from reinstall ?
I would guess that you need to use Protector Suite QL to make the user changes.
I have a VGN -SZ2XP.
I have the same problem.Did you find the solution? If yes please tell me the answer.
many thanks
