While I was cleaning my laptop the"Ctlr" key popped out. itlooks like nothing is missing but i can't figure out how to put it back. Has anyone a clue in doing so or where to find a step-by-step guide to fix it?
Thanks
Hi ramplanero,
I've sent you the Key replacement guide in a Private Message, click HERE to view your messages ..
I hope the guide helps..
PS please try to only post once otherwise this can cause confusion..
Key back in place.
Thanks
Excellent..
