I have a BT Voyager 2091 wireless router, but am unable to link to my VGC-V2M wirelessly. (Ethernet works fine). Do I need to purchase a wireless adapter, or if not, can anyone run me through the settings I need to alter ? I believe I have been through all the necessary proceedures setting up a wireless network, but still no luck !! Any assistance would be much appreciated.
get a wireless adapter better.
You need a USB wireless adaptor as the V series doesn't have space for PCI cards
Belkin Network Card is great,
Dont buy a USB adapter coz you can use a network card on it.
With all the respect man, but USB can be broken easily, but Network card is protected inside the PC.
I have both
Buying a PCMCIA Wireless card is fine as long as you don't want to be networked when/if you want to plug another PCMCIA card in.
USB is less restrictive.
the USB adapter is about 10cm long, where 1 cm is attached to the machine, how that cannot be broken?!
if it doesn't get broken a lot, why did Belkin created a stand for it?!
Ahh you see I was going to say PCMCIA, but I wasn't sure it had it
