A while back I noticed my camera doesnt workany more. I'm not sure why or if it was due to an upgrade or due to a fault or driver failure. I have version 2.2 of the software installed. When i launch sony camera capture utility it comes up with a blue screen and says no input as if no camera is installed! 😞 help! any suggestions?
Hi Gurj007.
What software is version 2.2?
You should have VAIO Camera Capture Utility Version 2.2.03.11150 installed.
Is the Camera showing as installed correctly in Device Manager? If it is there, what is it installed as?
The Ricoh camera driver is attached to the bottom of this post.
