VAIO VGN-FS315H PROBLEM
kaeferle84
Visitor
Hi,
I have a very specific problem with my Vaio notebook. It just freezes after about 15-30 minutes, display stays on, and only possibility is "hard" down. It also doesn't reboot afterwards.
Problem is not with battery or adapter, and RAM and HDD problems can also be excluded. And about cooler - it is not really overheated.
Any ideas ?
p.s. Wanted to update BIOS but the server is not responding. :S
Thanks in Advance
5 REPLIES 5
budgetmil
Visitor
I would say that something is overheated in your machine...
profile.country.pt_PT.title
V57...
Contributor
kaeferle84
Visitor
I tried to download from there, but its not available. Maybe is server down for some time.:(
And budgetmil, as i said, I thought also it could be overheating, but the notebook is not overheated at all.:S
V57...
Contributor
Hi kaeferle84,
I tried now and it's available...
Blencogo
Hi kaeferle84,
To check if your processor is overheating, download a program to check CPU temperature.
If you are using XP, I suggest MobileMeter
If you are using Vista, then try PC Wizard 2008
Both are free.
Post your CPU temperarure here when idle and when playing a game or a DVD.
:wink:
