hi there,
Vaio control center in not working in my VAIO - VPCF12C5E. its keep on crashing. and if i click on it in the control panel getting an error message no associate file has been allocated in the default programes. could some body help me?
Thanks
Have you installed all available updates for your Vaio using Vaio Care?
If you have then all I can suggest is that you download and reinstall Vaio Control Centre. You can download it here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCF12C5E
Hi there,
Thanks alot for reply. i have tried to re-install many times, but the problem is it is crashing and when i try to open it from the control panel getting an error message: "the file does not have a programe associated with it for performing this action. Please install a program or create an association in the default programes control panel".
Do not know whats wrong.
