hi,
I need your help my viao lap top dosent want to open it only shoe me text casll system operation not found
It will either be that your windows installation is corrupt - in which case you need to maybe get your OS CD, boot from it and do a repair install
OR
your harddrive has died
Hi littlejoman,
welcome to Club VAIO..
You're Vaio has a hidden HDD recovery partition so as long as it has not been deleted and your HDD is not damaged you should be able to recover your Vaio back to the original installed OS and programs just as it was when you first used your Vaio.
To do this Start your Vaio and when you see the Vaio logo screen press F10 repeatedly this normally would start the recovery process.
