Hi, is it possible to replace the hard drive despite the hybrid drive?
My concernings regards the system files and cloning to the new hard drive. As far as I now the system files are located on the small SSD, so when i replace the HDD will i then have two hard drives with system files or?
I wan't to upgrade the hard drive to a Samsung SSD SATA. Should I install it as a single HDD drive or a slave/second HDD drive - considering the hybrid drive?
Anyone having experience with this?
Thanks in advance!
