Start up problems with my VGCLT2S
Lobsa
Visitor
HELP!
I've had my VGC-LT2S for nearly a year and today when I turned it on it sounded as if it was on but the screen remained dark grey. My desktop, windows etc never started up. What's wrong with it?
I've tried re-booting and taking the power lead out. Can I try something else or is it a hardware problem?
I hope someone can help
Thanks
1 REPLY 1
Blencogo
Hi Lobsa and welcome.
Did you see the first Vaio screen before windows tries to load?
You do have a S-Video output. It may be worth connecting this to a display like your TV to check if it is the Vaio's screen that is faulty.
If you look at the screen closely with a torch can you see anything? (Just to check if the backlight or inverter has failed)
:thinking:
