Sony VAIO VGN-FZ11Z WLAN ISSUE!!!!!!!!!!!
Potageezer
Visitor
Hi all,
I have recently purchased the above mentioned notebook.
Using Vista Ultimate I have this annoying problem. My WLAN turns off at least twice a day. At the front where the WLAN switch and light is located, it shows that the switch is on but the light is off? The computer is connected to the wireless router but has limited access? The only way I can rectify the problem is to reboot the system.
Is there a patch available? can anyone advise me?
Thank you in advance.
1 REPLY 1
rich912
Contributor
Hi Potageezer,
You could try updating your Wireless Network Drivers from here .
Go n-éirí an bóthar leat
