SONY Vaio Duo 11 does not boot up
OSxy10
I have a hardware problem on my Vaio Duo 11.
After working properly for some months, it crashed with a blue screen and now it does not turn on anymore. I have already tryed turning off the system with a long press of the power button, as well as turning off the battery through the small hole. Even the Assist button does not work.
The only sign of life it gives is a blinking led code, as follows: yellow "wireless" led blinks, immediately followed by green "power" led; then around 5 seconds pause and the yellow-green blinking starts again. This goes on until I keep the power button pressed. When I press the power button or the Assist button again, the blinking code restarts.
What does such led code mean?
Blencogo
Hi OSxy10 and welcome to the Sony User Community.
The manual says nothing about the WiFi indicator flashing - only the Power and Charging indicators.
If Vaio Care Rescue Mode does not load when you press ASSIST,  I think I would phone Sony Vaio Support and ask their advice.  As you say, it may be a hardware problem.
:thinking:
1 RISPOSTA 1
Blencogo
:thinking:
