I need nVidia GeForce Go7400 GPU graphic &/or chipset for Sony Vaio All-In-One desktop Motherboard VGC-LA2. Unless other
graphic card or chipset can be used.
Problem is power-on and screen goes-off. Press Monitor-on switch screen comes-on and in 2-5secs off again. After warm
screen sometimes screen stays on for a while or longer a;though rarely. same repeat on/off.. According to sony web site seems
nVidia GeForce 7400 graphich chipset problem so advise solution.
I hv seen other user with same problem not yet supported by sony. I have noticed other model with same chipset supported free by Sony.
I hv used for basic purpose no games, also mostly use laptop yet just after 3yr extended warranty this hv stopped my expensive pc.
I hv done Factory reset still the same at BIOS screen as well as after Vista startup. Also sometimes crash with
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 2057
I can see faint desktop behind Black-screen.
Hi mukesh111,
Try shining a torch on the screen - can you see the desktop?
If so the problem sounds to me like a simple backlight failure. The inverter that supplies high voltage to the backlight may have an intermittent fault or a connection may be dodgy.
I would have this checked first as it will be a great deal cheaper than the graphics chip or the motherboard - both of which may be too expensive for economical repair.
Hi here,
I notice this was posted some time ago but hopefully someone can help..
This is the problem I have. How do I replace the inverter?
I was just about to through away the computer as most people said I needed to buy a new motherboard and it was not worth it.
Thanks
Richard
I have found you can buy inverters but not a clue which one I would need... Is there a way to find the part number?
Thank you in advance
