Hello,
I have a new Notbook by Sony. Its the A617M. Till the first time I startet the notebook I thought , that it's very slowly. Especially when I haven't connected it with the power-cable (when it runs with the accu), the notebook cannt connect with the internet and programs are running very very slowly. Can you please help me? Otherwise I have to give it back to the shop where i bought it. My Laptop is 5 days old.
Thanks
Check you power profiles.
You can set power profiles which extend the battery life. On my Z1RSP, I can extend the battery (accu) life by running a slower CPU, forcing the DVD drive and Memory stick slot to OFF.
It is quite possible that you machine can also turn off the external ports as well (LAN, wireless and dial up).
Worth a check. Try modifying the "accu" profile and set everything to Maximum speed and performance. Try again and see if that helps.
Can you tell me where I can modify my accu profil? I cant find it.
Thank you very much
Thank you very much
No its not faster. The most important thing for me now is to make the internet work in accu-modi. Is so biazar, when I disconnect the powercable iam offline! I tried it with or without the Vaio Power Managment, it doesn't work.. you still have an idea?
In the help-file I get to know that the notebook can deactivates wireless-lan when it runs with accu-power. Unfortunatly i just can de/+activate LC DISPLAY and CPU properties in the VAIO Power Mangement. Do I habe a possibility to change this? Where?
thank you
Yuhuu, it works. Thanks for you help, i had to change the network settings. There is the possibility to switch on the Wireless-Lan using accu power. thanks!
