*SOLVED* Problem: Sound over Headset and Speakers at the same time
Cub3
Visitor
Hello,
I've got the following problem and i've been searching the INet for several days but can't find any sollution...
Each time I plug in a Headset on my 3,5mm plug I hear the Sound on the Headset and at the same time on the speakers...
How can I dissable this??? Is it a hardware or a software problem??
I've got an Vaio FE21M
OS: Windows XP
Audio: SigmaTel High Definition Audio CODEC
Thank you so much for any help!!!!
3 REPLIES 3
Blencogo
Hi Cub3 and welcome.
It seems to be a Registry problem but I have only heard of it on Vista machines after downgrading to XP. However, the symptoms sound the same.
See if the solutions in this thread work for you: -
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=44938&offset=0
:wink:
Cub3
Visitor
hmm thank you for the hint but it does'nt work... :slight_frown:
i can find [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318} but everytime i try to change the pin.reg and reboot my vaio does'nt start and i have to load the "last working settings"
maybe it is an driver problem??? can anyone tell me where i can download drivers newer then 5.10.4946.0 for Sigma Tel High Defenition Audio CODEC??? would be great!
Cub3
Visitor
yeah i just solved my problem!!!
i just had to modify the pin.reg from this post http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=44938&offset=0 so that it would work with my VAIO FE21M
i'll attach my modified pin.reg file for Vaio VGN FE21M OS: XP
thanks for your help again Blencogo :wink:
