Scroll doesn't work with Touchpad.
NChristoffel
Visitor
I've done a clean install of Windows 7 Ultimate on my VAIO VGN-FW31M, it works great by the way. But I have a little problem, the scroll doesn't work anymore on the touchpad. It's quite annoying because I used it a lot. I already checked the drivers but no driver for the touchpad. Does someone has the same problem or maybe a solution for this problem?
2 REPLIES 2
Thalamus.
Champion
Hi NChristoffel,
wlecome to Club VAIO.. :slight_smile:
I seem to recall reading that another vaio owner installed the Vista driver so I guess you could try downloading and re-installing the original pointing device driver for your Vaio model from the Vaio support site.?
exabart
Visitor
One of the VAIO FW-51 models sold in the Netherlands (I'm not sure which one exactly) is shipped with 64-bits Windows 7. Download the corresponding driver for the Alps Touchpad and you're fine!
(Download it from the Dutch VAIO support site. The FW-31/41/51 share mostly the same hardware, so if you're looking for W7 drivers it's worth checking out the 51 series which was shipped directly with W7)
Success!
