Hi Can any one help,i have downloaded i think all the latest drivers for my Vaio notebook,because when i switched it on the screen size only fills the monitor 3/3rds,leaving 3ins of black border all around the screen.Have tryed to reset this,but no luck.If you could help,this would be much appreciated.
Regards
Sounds like you need to reinstall your video driver.
What model Vaio do you have?
What operating system are you using - XP or Vista?
Are you using the original operating system?
Hi,could any one help me find the correct graphic driver for,my Laptop,that is running windows xp,as the screen has decided to shrink to 2/3rds,leavig a 2-3ins black border running all around the veiwable monitor.I have already done a windows repair,but with no effect.Any suggestions would be greatly appreciated.
Thank from a (newbe)
Go to Device Manager and expand Display Adaptors. Right-Click on NVidia 6200 and choose uninstall. Reboot your Vaio and try to set the screen resolution.
If this does not work download the latest Sony driver.
The latest Sony Driver is NVIDIA GeForce Go 6200 Graphics Driver Version 7.0.8.6 for Windows XP.
Download this driver from here: -
http://support.vaio.sony.co.uk/downloads/info/info.asp?site=voe_en_GB_cons&url=Downloads/NV/D/VID/NV...
Go to Control Panel -> Display -> Settings
and set the correct screen resolution of 1280x800
If this is not available, reinstall the driver.
Hi,the highest the screen resolution,will go to is 1024 by 768,so i downloaded the driver,and when i doubled clicked on this to open,it asked me if i wanted to open all.This i done,then i went to device manager,but no display adapters were showing,so could not delete anything.Tryed opening this again,and then rebooted to see,if this would make any difference,but nothing happened.Still the same,and no display adapter is showing.Would i be better to give up,and to do a new restall,or would this not make any difference.
Hi catweazel,
What is currently listed in Device manager > Display adapters.?
Hi catweazel,
Do you have any unknown devices listed.?
