REPLACEMENT KEY
joffvaio
Visitor
REPLACEMENT KEY
Hello can anyone help?
i have dammaged the "b" key on my vgn-fs215m what can i do i had a spare key tryed to replace it unsucessfuly im affraid now the rubber button underneath the plastic face of the key is damaged i dont want to pay lots to replace the key any ideas?
otherwise im resorted to cut and pasteing b's :cry:
thanks.
6 REPLIES 6
Thalamus.
Champion
One of the Forum members recently posted a link for nexttronics.com not sure if they could help you?
profile.country.en_GB.title
kee-lo_
Member
Sony will send you up to 5 (!) keys for your keyboard. All you need to do is ring VAIO-Link
No idea why just 5 though
Thalamus.
Champion
Perhaps that's what Sony class as a handfull... :smileygrin:
kee-lo_
Member
Hehe
joffvaio
Visitor
how do i fit them i already tred to fit a key and was unsucessful the key broke
William
Visitor
Thats why Sony will give you a key :slight_frown:
They know that in the end you will send your Laptop to them for a new keyboard.
Joking aside it is very fiddly and very hit and miss. Its not impossible but nearly, unless there is any damage to the underlying bits.
