where can I get a replacement for my vaio keyboard serial no. vgp-wkb5gb. Truth is I spilled some red wine on it.
Solved! Go to Solution.
When I search eBay for vgp-wkb5gb I get 34 hits for keyboards for different Vaio models, 33 of which are new.
http://www.ebay.co.uk/sch/i.html?_trksid=p4634.m570.l1313&_nkw=vgp-wkb5gb&_sacat=0&_from=R40
Hi mikeboyatedin and welcome.
You will find several new ones on eBay - just enter the keyboard into the 'Search' field.
However, you need to match this to your Vaio Model and so you may find it easier to buy a third party wireless keyboard from Logitec or Microsoft.
Blencogo many thanks for that post, however cannot find any new or even working keyboards with this serial no. on e bay, or indeed anywhere. Are there compatable ones and how do I go about getting the right one?
Hi Blencogo, have tryed this on ebay and do not get any results. Can you send me a link to what are you typing and ebay site where? If I sound like a total ejit (dickhead) its probably because I am...........Mike
Hi Mike.
No worries - these things are not always straightforward.
Just click on the blue link here: -
