Hi Guys
Im new to the message board could someone please please please help me i need to know what key type the keys for the VGN-NR21J are and also how much a replacement battery would be for the same model Pleeeeeeeaaasseee help thanks guys
Hi BigSony82,
welcome to Club VAIO..
Replacement batteries can be expensive, as to the price you'll need to contact vaio support for a price for a replacement battery which from recollection is a Sony VGP-BPS9/B..
Be aware than some retailers on the internet sell 'non Sony' compatible batteries with the same battery model number..
Have you broken a key on your keyboard.?
If so you may be able to find a replacement key or keyboard for your vaio via ebay or similar.
Or I afraid a replacement keyboard from Sony support is possibly the only other alternative. 😞
Hey thanks for replying
Yeah my nephew took the 'I' key off the laptop and broke the fitting too you can still use it but its annoying lol.
I've found a website were it says these keys are for SONY Vaio ALL VGN-N VGN-NR NR VGN N Replacement Laptop Keys but it says select key type which is either SC11 SC28 or SC38 but i dont know which type it is here's the link.
http://www.replacementlaptopkeys.com/servlet/the-265/SONY-Vaio-ALL-VGN-dsh-N/Detail
