Hi Guys,
Am new to this forum, I need your help. I have this Sony Vaio but my cd / dvd creator is not working or it is not even installed when I bought it. The Sonic Record Now for burning cds is what I need. Well I wanted to transfer some photos to a cd but my F drive says it's not accessible, incorrect function. Please help, thank you, Christine.
Hello Crystal
Same for me last year,I lost this option?????Why??
I reinstall my DVD and It's work very good since this.
Regards
Jacques
Hi Christine,
welcome to Club Vaio..
In Device manager > CD/DVD devices are there any warning icons or error codes.?
Depending on your vaio model you should be able to re-install Record now via the Vaio Recovery Utility..
Click Start > All Programs > Vaio Recovery utility.
Click continue on UAC window if it appears.
Select re-install programs, then click Start.
Then select the application from the list and follow the installation instructions..
Hi Jaqcues,
Thanks for your prompt reply. I have a VGN-FS285M and I think the programs came installed so I do not have softwares to reinstall them, how did you do yours?
Thanks for your time.
I can read and watch dvds and listen to music from discs but transfering photos from my hard drive to a cd is not working.
Thank you,
Christine
Hi T,
Thank you for answering in detail. I tried what you said but I can not find UAC, I have a VGN-FS285M, quite old I think bought in 2005.
I think my problem is quite easy but I do not know how to solve it, in my vaio link, it says I have a Sonic Record Now but I don't have it installed thus I can't burn cds like my pics to a cd...
I have an old Roxio easy cd creator but Vaio says it ain't compatible 😞
I have a Sony My DVD installer disc, does that help?
The F: drive says incorrect function and F: is not accissible if I try to copy the pics to the f drive.
Help please.
Have a very Prosperous New Year to you and to all vaio Friends!!!
If you know a sony vaio link I can download cd reader for free, do let me know.
Thank you,
Christine
Hi Christine,
my mistake.. :smileyblush:
Goto Start > All Programs > Vaio Recovery Tool and click on Vaio Recovery utility.
Once the Vaio Recovery utility has loaded, click the options button and select Recovery Specific Applications that were pre-installed, click OK, then Yes and Yes again.
Select Record Now from the list and click install..
Hi T,
Thank you very very much...your suggestion worked!!!
I can't thank you enough for your help and time replying to me and to anyone who needs help.
You are a genius!!!
Thank you thank you!!!
C
