problem with windows virtual macine and vaio
dazwan
Visitor
hi,
I have the VGN-FE41Z and i used windows virtual machine so that i can use XP, i want my virtual machine to be able to go on the internet, do i need drivers, or anything, if yes please send me links i really need it please :slight_frown:
thanks in advance
3 REPLIES 3
MattWilson
Visitor
Is the internet connection working in Vista as VM will just reroute it through that. Does the XP device manager have any little yellow triangles in it? :thinking:
dazwan
Visitor
nope no indication of that :slight_frown:
but its connected
MattWilson
Visitor
Are you using an ethernet connection or a wireless connect?
You will have less problems with a wired connection. The drivers should already be installed for all the devices supported by VirtualPC.
:thinking:
