Hi, I have problem with my screen in my vaio. From some time when i power on laptop screen is purple/pink at starup and the same its happening when I switch off screen/power saver screen is purple for about 10 s and after that its getting back to normal color. Anyone Know what is happening with this??
Thx
Yes I am.
Hi Nox2,
try booting into safe mode do you still have the same problem.?
But I don't think that safe mode will help, becouse I have also purple screen when I power on laptop, whet Vaio logo shows on the screen. I've tryed and it's the same in safe mode.
How can I check what type of mould? Its in this vaio?? I need to know number like this 05K9879.
I was talking about this: http://cgi.ebay.co.uk/NEW-SONY-VAIO-Vgn-Fe21S-15-4-WXGA-LCD-SCREEN-A_W0QQitemZ110265508997QQcmdZView... if I will buy new screen and just replace it will that help??
Hi Nox2,
I wouldn't recommend that you buy anything until you know what's causing the problem..
