Problem with ATI Rage Mobility-M1 PCI (Deutsch)
FunkyPopper
Visitor
Hello,
I have a problem. I installed Windows 2000 Pr. on my old Sony Vaio Notbook PCG-C1VFK. Then I downloaded a Driver from Vaio-link and installed it. Then when I restarted the complet display was filed out. When I restarted again on the right and on the left are 4 zentimetres wide black touches. How can I get the complet display again?
Please help m.
10 REPLIES 10
profile.country.en_GB.title
kee-lo_
Member
You'll have to reinstall Windows 2000
robpaxton
Explorer
Are the display properties set to the correct native resolution of the display?
FunkyPopper
Visitor
I installed Windows 200 twice. And after the first installation I had the same problem. How can I check if the properties set to the correct native resolution?
kee-lo_
Member
Right click the desktop
properties
settings
there move the slider to a widescreen resolution
FunkyPopper
Visitor
I can't slide , I only can set 640 x 480 pixel.
kee-lo_
Member
Install the graphics driver on your CD-ROM
FunkyPopper
Visitor
I can't installe it on my CD->Rom. You think of my cd-rom from sony?? I haven't it, I lost it!!!
robpaxton
Explorer
The Win 2000 drivers are available from Vaio-Link
Go to the Download area and enter your serial number. Follow the installation instructions carefully. If that doesn't work then you may have to force the driver install.
FunkyPopper
Visitor
I installed the driver, the homepage gave me after entering the serial. Then I installed it. What means to force the driver or how can I force it??
