hello all,
i got a problem with my vaio FZ21M...
when i burn a dvd or cd, the following error appears : Power calibration error (with any burning software)
i got the same problem a few month ago, and there were an update for the disk drive, after that, everything was all right, but now, there are no update... what can i do to solve that problem ?
regards
Alex
Hi Alex,
There can be many reasons for the error message you are receiving, but to narrow down the problem have a look at this LINK
It may be simply be a matter of cleaning the laser lens...
Hello Rich,
thx for you message, i change my media, and it s gonna be all right...
It is verry strange I user Ritech DVD and with that, i had the problem... it s not bad media...
now i use Verbatim dvd, and it work well
Thank you verry much:smileycool:
Alex
Hi Alex,
I'm pleased to hear that you have solved your problem. For some reason Sony notebook CD/DVD drives seem to be very "media sensitive". Verbatim have always worked well for me also....
Thanks for the feedback
See you've not lost your touch then Rich..
No complaints to date Thalamus
