Hi,
I have a pcg-v505ap notebook. The cpu fan is dead. I have ordered a new one and started to take apart the notebook.
I need some more help to take the cpu fan assembly out of the notebook. Does anyone know how or can anyone help point me to where I can find some manual or some tips on how to replace the cpu fan. thank you so much.
I see so people have looked, anybody, anykind on help on this?
I have never managed to find a disassembly instruction for your model. Maybe if you have a look at the schematic layout for this series it will give some clues.
Have a look
here.
Rich912 Thank you for your response. I took a look and it does look like my cpu/fan assembly. Since the schematic layout looks like what is in my notebook, I will assume that it is same on the PCG-V505AX / V505AXP models, do you have or know where I can get or look at disassembly instructions for either the PCG-V505AX or the V505AXP models. I have a feeling it will be the same for my model. thanks again, i see a little ray of light at the end of the tunnel!
