I have a VGN-FS215E series, the memory stick slot can read 2 and 4 GB memory sticks normally but when it comes with the 8 GB memory sticks, it doesn't read it and it tells me that the memory stick is not formated and i have to format it, although it is formated !! any suggestions ?!!
I thnik there must be an update for that problem and most of the electronics that came after 2007 (Memory Stick supporting machines) supports 8 gb MS Duos.
Hi bach and welcome to Club Vaio.
There isn't an update for your model.
I would try the one listed for the FS315 which can be downloaded from here: -
Memory Stick Driver Update Version 2.0.4.7
It should work ................................... as long as your reader is not too old!!
wowwww it worked really good, thanks alot, you are the best. Now it can read the 8 GB memory stick normally. Thanks again
