my VAIO doesn't read 8 GB memory sticks
bach
Visitor
I have a VGN-FS215E series, the memory stick slot can read 2 and 4 GB memory sticks normally but when it comes with the 8 GB memory sticks, it doesn't read it and it tells me that the memory stick is not formated and i have to format it, although it is formated !! any suggestions ?!!
3 REPLIES 3
profile.country.en_TR.title
Twinsen
Visitor
I thnik there must be an update for that problem and most of the electronics that came after 2007 (Memory Stick supporting machines) supports 8 gb MS Duos.
Blencogo
Hi bach and welcome to Club Vaio.
There isn't an update for your model.
I would try the one listed for the FS315 which can be downloaded from here: -
Memory Stick Driver Update Version 2.0.4.7
It should work ................................... as long as your reader is not too old!!
:wink:
bach
Visitor
wowwww it worked really good, thanks alot, you are the best. Now it can read the 8 GB memory stick normally. Thanks again
