Can anyone help me?
After 3/4 hours of work my laptop swith off itself automatically without any reasons. After that with the power button the laptop start again without appantly problems......and than start the hystory again.
Thanx felly...but I check my pc with the latest version of Norton.....than I don't think so......
Can anyone help me?
Is the laptops bottom hot?
might be a problem of over heating.
the laptop will switch itself off if the CPU has reached critical heat level. you need to check your fan.
do u have a diagnostic CD?
