Low volume
co2laser
Visitor
Low volume
Hi, The sound on my new VGN-C2S seems very low has anyone else the same problem? Is the only fix a set of active speakers? Regards co2laser.
8 REPLIES 8
MattWilson
Visitor
When you see the VAIO logo when you switch on your VAIO hit F2 sto go to the BIOS.
In here there is speaker volume. Stick it up to 8.
EU law means that audio equipment has to be quieter than that of the US or other places but because sony use the same machines all over the world they have to limit it using software, hence you can change it!
:slight_smile:
co2laser
Visitor
Thanks for your reply Matt, done that and it's better. Thanks again
MattWilson
Visitor
You are very welcome
Enjoy your louder VAIO :wink:
Hottee
Visitor
Can I do the same for my VGN-C1S? My volume's also extremely low on some applications.
MattWilson
Visitor
You should be able to just restart your VAIO and hit F2 to get into the BIOS and find the speaker volume and stick it on 8.
:slight_smile:
Hottee
Visitor
Wow - that's better. To think, I'be suffered in virtual silence for 8 months........
Cheers Matt! :clap:
MattWilson
Visitor
Cheers Matt! :clap:
Your welcome :slight_smile:
Enjoy your new lease of life with a louder VAIO :smileygrin:
profile.country.sv_SE.title
pln8421
Visitor
I have VPCS13S9E and cant find that setting in BIOS. I come in with F2 but how to find the settings in BIOS? I have gonne through everything i think but nothing about sound.
