my new laptop won't charge up, i recently brought it, i've checked the plug-it's working but my laptop won't charge up the adapter has a green light but i don't know if that's not working or the laptop battery isn't working. any help would be much appreciated!!
thanks in advance
Hi sonywatford
welcome to Club VAIO..
Is you battery securely locked in place.?
If so simple way to check if this is a battery or possible hardware problem is to take your Vaio to a local stockist and ask if you can try another similar battery in your Vaio..
ok i've taken the battery out and put it in but still no luck, i haven't had a chance to take it to the nearest shop but it seems like quite a lot of hassel as i'm at uni atm and i need it, i'm currently using my friends laptop
would you suggest that i call them? if so does anyone know there number?
thanks once again
hey sonywatford i have the same proble and if you taka off the battery for 10 min while the computer is working but first put the plub in and after 1o min insert the battery back from where you taked it and than restart the computer and when boots up open the mobility center to check if that works for you.
I does work for me And now the battery is full charge .
Hi skyfacker_92,
thanks for the information, hopefully it will help sonywatford..
