Ok here it goes: Does anybody know what do i need to reinstall so that the volume on the laptop(the buttons ) can work again !! ok new edit the buttons work but i have no visual efect of the volum on the screen!! how do i get it back?!
(i uninstalled some of the original sony vaio apps ) :smileygrin:
Hi Gagauza and welcome.
These functions are controlled by the Sony Utilities and I am not convinced they are all available for download. As you have found out it is dangerous to uninstall any Sony programs unless you know exactly what they do.
Try re-installing all the seven Utility Installers by following the instructions on Page 25 of your Recovery and Troubleshooting Guide - download here: -
ftp://ftp.vaio-link.com/pub/Manuals/RecoTS/2008Q2_TRG_EN.pdf
If that is not possible, try downloading the Original Utilities Package for your model from here: -
http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&c=0&s=VGN...
Extract the files to a new folder and run the Setup.exe for each of the seven Utility Installers.
