Hi all.
I had my FS315E back in November of last year. I noticed earlier this week that it is goin weird!
Some thumbnails have a blue font underneath instead of the normal black.
Does anyone have any ideas as to why this is???
Some within the same folder are black.
Thanks in advance if you can help me!
Tash Edwards
Thanks for the suggestion but it hasn't changed it at all.
Any more ideas!!!
Cheers
any chance of a screenshot of what it looks like?
weird, everything I find it pointing to that
right click a file that is blue and select properties then advanced, is compress ticked?
if it is, untick it, and does it go back to black?
I'm totally lost on this one
That suggestion seems to have worked. Don't know why the first one didn't!!!
Thanks so much for your help!
You don't have to be lost anymore!!!
lol *phew* :smileygrin:
glad it is sorted
