Hi
The integrated camera on this brand new sony (Vista) works one time only per boot, if I start camera capture utility it works, close the utility and try Skype and it says the camera is used by another program.
After a reboot the camera works again but again one time only.
I have been reading some on this forum but the search does not work? Am I missing something?
Regards All
Identical problem here. I have a VAIO VGN-FE41S.
Thats interesting - I cant even get the camera capture utility to work in vista on my SZ3 - when I try to install the Vista Utility (from the sony vista driver site), Vista claims the software you are installing is not designed for Vista.
Same problem here! Actually when I start the camera capture utility from the system tray there is no way I can close the application (only by means of task manager of course
Chris.
Exactly the same problem here guys!
yep, same overehere with the fe41s.
Same problem with my Fe41Z.
And yep, I have the same problem with my VGN-FE41S.
See also: http://club.vaio.sony.be/clubvaio/BE/nl/forum/viewthread?thread=39704&offset=10
(screenshots in dutch though).
I have opened a ticket for this issue at the Sony Vaio helpdesk in Brussels 10 days ago.
Waiting for a feedback...
Wouter
