Hi all, I am wondering if it is possible to reset my VAIO VGN-CR21S Back to the way it was when i first swtiched in on. I am also looking to do a reshell. I understand that it is three years old but it is the first laptop i have owned and intend on keeping it.
All help appreciated
Cheers
Lee
Message was edited by: lee cummins
Hi Lee,
Download your Troubleshooting and Recovery Guide from here: -
ftp://ftp.vaio-link.com/pub/Manuals/RecoTS/2007Q3_RT_EN.pdf
Follow the instructions on Page 36.
You will, of course have to reinstall all the Microsoft and Vaio Updates.
Good Luck.
Have to install new hard drive as original broke the other day. how do i get original disks and how much. A link would be great
Cheers
Lee
You can purchase a set of recovery discs from Vaio support which should allow you to restore the original Vaio supplied OS and applications..
You can find the contact details for vaio support by either clicking Support at the top of this page or by using the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then next Select Model..
Then click Log-In
Once logged select Get In Touch.
Then Click on the Out of Warranty tab, then Phone support.
The price can vary depending on Vaio model..
