Errors with drivers model: VPCW12J1E
profile.country.el_GR.title
billef
Visitor
  • I cant find the exact model  VPCW12J1E in support. I have VPCW12J1E and not VPCW12J1E/t or something. Is there a link with drivers for VPCW12J1E? if not which model's drivers are the most "proper" to download?
  • I have probelm with SD card reader. It always says that my sd cards are write-protected.
    • I tried to unistall-reinstall the driver
    • i tried it with a lot SD cards
    • I once got access after restarting the netbook and letting the SD card inside. But when i tried to eject it -not maunally but with "safely remove hardware and ejct media" option - it said that it was used by another program or window. what program/service could be using the SD card and not letting me safely remove it?
    • SD Driver is: SDA Standard Compliant SD Host controller v. 6.1
  • My bluetooth driver is missing. I download a driver (i dont know if it was the right one - it was auto selected by windows. During the installing process it stopped by saying that it couldnt detect bluetooth device in my netbook.
    • I got a link to BroadCOM - WIDCCOM Bluetooth for Windows.
I have Windows 7 Ultimate - 32bit
Thank you all in advance.
Message was edited by: billef
3 REPLIES 3
billef
Visitor
I think i resolved my SD probelm - for now - I downloaded a driver RIDFMC-70165670-32.exe - It was also selected from windows (i went to device manager and selected the "Scan for hardware changes")
Blencogo
The /t, /p or /w on the end of the model VPCW12J1E just refers to the colour - black, pink, white etc.  The drivers are the same for all three.
You can download all the drivers from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCW12J1E_W
You will see the 3 Memory Card Drivers and the Bluetooth Driver are there.
:wink:
billef
Visitor
Thanks for the link. It got helped really! The thing now is that Ive installed my bluetooth driver but still something is wrong.
  • Bluetooth Peripheral Device - No driver found
  • Bluetooth AV Remote Control Target - Ready to use
  • Bluetooth AV source - Ready to use.
I have an iphone and a nokia device.  I tried to connect my iphone with my netbook. Both devices found each other but there was a problem in the connection.
The problem located in the bluetooth peripheral device driver. its still missing. I tried to see what is the bluetooth peripheral device.
I went to --> bluetooth devices --> Show Bluetooth Devices.  There were two devices icons (iphone and nokia - I also tried with nokia) and there was a notify triangle icon at the corner of each device icon.
I pressed right click and then i saw a troubleshoot option. I clicked on that. The result for each device was that a driver was missing!!! Why would I want a driver for my iphone/nokia device?!!! Is this really the problem?
:slight_frown:
