I have a VGC-V3S and the DVD drive has stopped working. It will read CDs but for some reason will not read DVDs. Can anyone help me fix this problem?
Ho joestockil and welcome.
Will it boot from your DVD Recovery Discs?
If it does then you have a software problem and it is probably fixable. If it does not then it is likely you will need a new drive because the DVD laser is probably faulty.
Hi,
I just tried to do that and now it will do northing at all. When I switch th ePC on it gets as far as the VAIO splash and stops, even without the recovery DVD inserted. To make matters worse I don't have a full recovery set on CD, just DVD
