Hi,
Has anyone else had problems when trying to run Vista Dreamscenes. If I open the Dreamscenes option my machine just hangs!!! I did manage to pick one of the Dremascenes but then all I got was a black background and no video!!
I am getting really frustrated at the moment
. I have just taken delivery of this new machine (AR51SU), but I have had loads of problems doing the Vaio Updates (some wouldn't, and still won't install, some said they were for the wrong version of Windows but then seemed to work). I still haven't installed any programs yet!!
Any help/advice would be really appreciated.
Obokeeper
Hi,
I am getting really frustrated at the moment. I have just taken delivery of this new machine (AR51SU), but I have had loads of problems doing the Vaio Updates (some wouldn't, and still won't install, some said they were for the wrong version of Windows but then seemed to work). I still haven't installed any programs yet!!
Obokeeper
Hi guys,
A couple of days ago i had to restore my AR71ZU again (for the 9th time). It's only 3 weeks old! I'm having a nightmare with drivers and updates. I'm beginning to think i should have just brought it back as it was DOA - Vista wouldn't install.
Anywho, last week i'd accidentally hit the tick all checkbox in Vista Updates and it had installed everything, including all the foreign language packs and Vista Dreamscene. I'm a bit slack with restarting it as i nearly always hibernate. I was curious oneday when i'd right clicked on the dekstop and saw the Dreamscene option greyed out. I did a bit of digging around and all of the desktop backgrounds were unrecognised. I'd selected a Dreamscene mpeg (none of the files were recognised) and my machine had locked up. I had to go into Task Manager and ended explorer.exe and started it again. Then my desktop came back.
Apparently it's a GPU driver issue. Short of using RivaTuner to hack and update the drivers it's up to Sony to decide when they want to make the update available. The guy at Sony Support said they're working on it. I'm fedup with my AR71ZU!!!
Somebody at Sony should be reading these threads!
Short_Round
