Hay everybody I have just bought sony vaio vgn-nr11z/s. Can anybody tell me weather this supports/runs blue ray dics.
Regards
Hi jazzmy and welcome to Club Vaio.
If you look at the specifications for the NR11Z you will see that the enclosed drive does not support blu-ray discs.
http://support.vaio.sony.co.uk/specifications/specifications.asp?site=voe_en_GB_cons&c=0&s=VGN-NR&m=...
The drive supports CD-RW, DVD-ROM, DVD±RW, DVD-DL.
The cost of a blu-ray drive would significantly increase the cost - probably an extra £150 for a read only drive and £300 for a writer.
