hi
my D drive somehow has got really messed up. it says i need to format it but i dont want to loose my work saved on it. plz some1 tell me what to do...this is really urgent. the drive says i can format it, quick format it or enable compression....
any help will be much appreciated
thnx
System restore the d drive to a time before it became a problem and use acronis true image or simply back it up to an external hard drive. I saw a seagate 300gig external HD for £104 at Maplins. Or use dvd disks.
thnx for the quick reply but when D messed up C got affected as well.. for sum reason there are no system checkpoints. im so worried...plz sum1 help!
Can you access any data at all on your D drive?
In the System Restore Wizard was there no system checkpoints at all?
Have you checked your system for a virus?
As your C drive is now corrupted as well as your D drive the data you want to backup may also be corrupt.
ermm...no and no
have you read my post on your other thread?
