Hello,
I have a desktop PCV RS 504. I have just bought a plasma tv and would like to connect it to my DVI graphic card. I have the cable to use a DVI output and a hdmi input. I have a problem to correctly define the paramater in my display control panel.[email protected]
Set the resolution of your graphics card to the exact resolution of your TV. you will find this figure in the manual.
